Old 09-01-2013, 08:18 PM   #3
jb92563
jb92563's Avatar
If you dont oil the cylinders before storage you will likely have rust in the bores after a number of years which will need cleanup before turning over the crank lest you score the cylinder and bust rings and loose compression.
I like the engine bag idea too, along with the oil fogging in each cylinder and put the plugs back in
