Old 08-31-2013, 07:29 PM   #771
steved0x
steved0x's Avatar
Originally Posted by trimer View Post
I thought it was 18 ft lbs for filter housing and 35 for the drain plug???
The stock drain plug is a lot higher, Pelican Parts says it is 37 ft/lbs and 19 for the filter housing (I guess not much diff between 18 and 19)
The LN Magnetic plug had a sticker right over the outside that had to be removed to insert the hex tool that said 19.
No leakage so far but I have only driven 6 miles
The dash says I am right at the bottom of the range, I'll check the dipstick tomorrow and see if I need to add anymore. 9 whole qts in so far.
Steve
