Originally Posted by sb01box
i had thought that i purchased all "rubber" wear parts. but I left out "compensation plates" which are really hard rubber spring seats at the top end.
there are two flavors, 3mm and 6.5mm for the front and 3mm and 6mm for the rear. All I could find is that these are"as required'.
I am contemplating using the thicker ones so that the car is 3mm higher.
any experience and or thought that you can share will be greatly appreciated.
thanks in advance
tad
The compensation plates are dictated by the paint codes on the springs. You can find the info in the Bentley manual.
