Originally Posted by Brad Roberts
Happens all the time.. run it!! Typically the pad is too SMALL and we end up with a lip on the outer edge of the rotor. This will not happen with these pads!!
Secret: I run rear pads on the front of the 2.5 and 2.7 cars ALL the time.
The difference is only 4-5mm of pad material. Gives me a little more rear brake bias ![Smilie](http://www.986forum.com/forums/images/smilies/smile.gif)
Have you ever put front base brakes on the rear of a base? I test fit a set they fit the caliper but extend about 1/64" over the inside lip. I then cut off the pin hole ear. I have a couple sets of EBC yellow non S front pads I believe I could still use.
