Old 07-26-2013, 12:14 PM   #11
Jittsl
SPB racer
The only reason I prefer the Rennline mounts is because they enable you to use latching hooks that, no matter how loose the staps become, can't fall off. I once had my GT3 (hand brake off, car in neutral) roll of the back of my trailer simply because I wasn't using latching hooks and the car had developed enough forward/back movement to simply drop the straps off. I think I'm right in saying that if you take Brad's approach you can't lock the hooks on. Correct? If so, I'ld go with the safe over sorry.
Jittsl is offline   Reply With Quote
