Old 07-11-2013, 07:43 AM   #1
southernstar
Paul, if the jiggle and pull method does not allow you to remove the key, then I suspect that once you have the switch detached (as I recall, two small screws), it will allow you to pivot it and remove the key. You may need a second set of hands, however.
Brad
southernstar is offline   Reply With Quote
