Old 07-05-2013, 06:23 PM   #17
schoir
Originally Posted by Hayden View Post
Yeah, it's stuck open. I will need to find a larger wrench. Thanks for the prompt reply!!
edit: got larger wrench. No way it's fitting in there. No box wrenches in that size at Lowes either. Tired of throwing money at this. Off to the mechanic... which I think is pretty ridiculous for something that is outlined in the owner's manual, which can't even be remedied through the way it says (since apparently, disconnecting the V-lever is the only way to get the ball connectors off.)
Hayden:
I understand your frustration... I have been there many times. So, I went into my garage and got the Sears Craftsman wrench for some better photos...Here they are...
As I said, this one will fit perfectly as it is just thick enough to get a good bite on the 19mm bolt and still fit in between the V-Lever and the convertible top frame B Pillar when it's all the way open.
Regards, Maurice.
schoir is offline   Reply With Quote
