Thread: Tiptronic P0733
Old 06-30-2013, 04:29 PM   #11
Okanebm
Update!
Pouring over some notes I made while doing the rebuild and the optest. On third top-off of ATF, when engaging all the gears in manual mode.....
1. brief light off of ABS light.
2. shifted out of manual by itself.
3. ABS light out.
4. Manual mode will not re-engage.
5. Shutdown
6. Re-start
After that I continued with the top off with no further issues again, test-drive, semi-sat, parked, always in drive issue started.
I'll be right back.
Okay! ABS light is on, starts in park, no reverse, and wants to go fwd in park, reverse, neutral, and drive..... Multi-function switch? Transmission Computer? ABS sensor? I'll continue to ponder with a scotch, no condition right now to be behind the wheel.
Okanebm is offline   Reply With Quote
