Any particular reason you're going for switched power? Only reason I ask is that the factory socket is non-switched... you could always just piggy-back off that and therefore the fuse panel would match the use. Or do you need more amps than the single socket rating?
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
