					Originally Posted by  Ian c
I attempted to do the oil on Sunday . Couldn't get the sump off to change the filter , so just changed around 4 quarts
Only 4 quarts? Withe the filter it usually takes 7+ quarts.
I changed the oil & filter today.  You wont get the filter off without a filter wrench.  I bought one 75mm 14 flute wrench from O'Reilly's auto parts part # 19903  $5.99
They stock it in store.
Pulled the filter paper apart to inspect for metalic (magnetic) particles with none present except for a few flakes of aluminum.
Magnetic particles would be a concern as it is an indication of bearing wear.
I also installed the magnetic oil drain plug.
You should come to an autocross at Qualcomm, and meet the gang.
I also highly recommend the Porshe performance driving school at qualcomm.
				"It broke because it wants to be Upgraded
Short Shifter, Touch Screen Dual Din Radio, 03 4 Bow glass Top  (DD & Auto-X since May 17,2012)
