Old 06-19-2013, 06:48 PM   #22
jb92563
jb92563's Avatar
Originally Posted by 1olddude View Post
It's not just Porsche that hides and denies common design problems. My Jeep Wrangler just surprised me with the dreaded "death wobble". It is a known problem with Jeep and dodge trucks but they deny it and won't compensate those who experience it. Vehicles with coil springs and straight axles are susceptible to it. It is actually very dangerous and scary when it happens. Usually it is a result of track bar bushings going bad, but it is tough to diagnose sometimes. Look around on the Internet and you find out just how common it is. Just spent $300 getting a new track bar, steering damper, wheel balance, and alignment. Throw Jeep in the same pile as some of these other car manufacturers. It's all about the $, and it will never change regardless of how many class action cases are filed. It is a crapshoot every time you get in a vehicle with known catastrophic problems that may occur at any time. I drive my Boxster and don't worry anymore. Yes it could self destruct but I will cross that bridge when I get there.
My 1999 Wrangler had the "death wobble" so I replaced the steering damper, it improved then I removed the front wheel drive shaft and the problem is gone. It was a worm u-joint in the front drive shaft. Easy to fix for under $80.
