Old 06-15-2013, 03:02 AM   #7
tomc88
tomc88's Avatar
hi,
on my Boxster, this is a line in connector that plugs your stereo into the Boxster's Haes 40W amplifier.
I bought this cable (google) - CT53-PO01
This cable assembly is over the top and there may be cheaper options.
I chopped off the connector block that I needed from this assembly.
Then I soldered it to some phono plugs.
This can then plug into the line outs of your stereo.
Also to get it to work, I had to wire the amplifier Mute wire (from the stereo) to the connector block. This mute wire 'turns on' the amplifier.
The OEM Porsche stereo manual has pin outs. Also there are some useful pix online and other info.
but if you buy the cable assembly CT53-PO01 or something similar, then you will be 90% of the way there
2001 Boxster S
tomc88 is offline   Reply With Quote
