Old 06-14-2013, 07:27 AM   #22
Perfectlap
Perfectlap's Avatar
Originally Posted by Izman1000 View Post
My smoke Depo tail lights showed up yesterday and I'm confused....
The new tail lights don't have a place for the side marker bulbs to shine through (the lights that wrap slightly around the side of the car and illuminate when the headlights are on).
There is no way to see the car at night, except for the license plate lights. How is this safe and/or legal?
Also, it doesn't look very good without tail lights that light up... What am I missing?
easy modification. I used an electric drill altough that's probably not what you should be using but I'm given to impatience sometimes. Anyway... there are two bulbs I believe that are attached to wiring, one wire is long the other is short.
I guess one is for the brake light and the other for the side parking light, which will continue to work after this mod by the way.
You have move them around in the housing so that they swap places. But there's a little plastic frame piece that makes it hard to squeez the one bulb through to the other side. I pulled back the rubber shroud on the bulb exposing the metal socket and tried to squeeze it through that little space but it was still to narrow. That's when I got out the drill bit and put a hole in that plastic piece. Be sure to pull all of the wiring out of the way so you don't inadvertently drill through the wires. I then took a pair of pliers and snapped off the rest of the plastic clearing the way so that the bulb could easily pass through to the other side.
This took about 5-10 minutes for each tailight. I'm sure there's an easier/safer way like using a soldering gun to melt the plastic and then follow up with the pliers.
Once you've swapped places on the the two bulbs you'll have the rear corners stay on as soon as you throw on the headlights. The inside lights nearer to the rear trunk light up when you hit the brake. Make sure those bulbs are properly seated so that little security pin near the edge of the bulb is locked into its little slot, otherwise the bulb might pop out under braking and you'll have to do it all over again just to snap in that bulb into the housing again. Also, for some reason on my set I had to turn on and turn off the the headlights twice to get the tail lights to turn on. But then that went away.
These tailights are the best bang for the buck mod so far. They are wayyyy brighter during the day so you'll wake up those distracted drivers behind you. The parking brake light is also much brighter/visible during the day. I parked the car on the street one time and I could see the parking light shining brightly some three blocks away. Easily the most noticeable thing in my field of vision. It was a narrow street where passing cars get very close to the parked cars.
As far as looks even my mechanic noticed them right away and commented it gives the rear an updated look... doesn't look so 1990's anymore. Kind of reminded me of the Carrera GT talights the way the LEDs are layed out.
BORN: March 2000 - FINLAND
