Old 06-12-2013, 05:26 AM   #31
insite
Originally Posted by j.fro View Post
This is great info, but I am lost on one important bit...how are you getting the ECU to add/subtract fuel from the regular programming?
i use a piggyback fuel controller. it splices into the MAF signal. at full throttle, our cars use the MAF signal + a stored map to determine fuel. the fuel controller monkeys with the MAF reading at the ECU to trick it into adding / pulling fuel. the unit is an APEXi AFC Select. pretty slick.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
