Would a bad O2 sensor cause a high engine temp Bank 2 sensor 2 is a flat line. I forgot that Dyno scan on my PC has scope functions. That sensor gives me about 2 sin waves when you burp the throttle then goes flat again. about .108 volts The trim is about 15% max. all the other are 5 to 60% .047 to .78 volts
