Old 05-19-2013, 04:29 PM   #4
black_box
DIY extremist
black_box's Avatar
Originally Posted by mcomet View Post
Yeah I found a old thread linked to this. Seems useful. Anyone know what fuse so I can check?
Boxster Projects | Parking Brake Sensor Switch
I had this problem with my 986 when I first got it. There is a little white plastic encased microswitch that sets the e-brake light. It's about $6, or you can use electrical contact cleaner on it.
You can jury-rig your way around a malfunctioning one the way I did (with no tools needed) so I could just get the top to operate:
From memory, on the driver's side of the E-brake you can yank on the plastic piece that covers the mechanism. Then you should see the switch and a two prong plug stuck to it, pull the plug out, stick a piece of wire or a paperclip into it to close the circuit. Jam it in weel and it will stick. Put the plastic cover back on if you want. Voila, e-brake light stays on (but not the tail brake light) and you can operate top at your leisure. I cleaned out the switch and it's been fine since.
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
