Old 05-12-2013, 01:32 PM   #14
Paul
Porsche "Purist"
Paul's Avatar
Age and vibration, it is attached to the motor which rocks on its mount when compared to the oil fill cap which is mounted on the firewall. Also a failing AOS causes low vacuum that collapses the tube when off throttle.
In regards to the RMS, I use the sheet metal screw method to remove them.
1987 924S. 2002 996TT. PST-2
