Originally Posted by drbodzin
I'm able to twist the flywheel about 10mm in each direction by hand. Is it suppose to spring back to the same spot? It goes back, but not with a sudden spring. Sorta "eases" back.
Your FW is good.
It doesn't need to spring back to the starting point, bat has to go back ther, and twist the same way to the other side.
When doing my project, I decided to replace the FW anyway ( thought I'm going to keep my car for ever). The new FW, acted axactly the same as the old one, only required a bit more force to twist.
