Old 05-09-2013, 08:09 AM   #2
jsceash
jsceash's Avatar
This could help, not 100 % sure but it should not hurt. First look and listen for a vacuum leak any of the small black tube that cross over the engine from the vacuum canister (passenger side) to the vacuum switch (Operator side) then to damper plate in the front crossover pipe bottom side. If no leaks disconnect the battery for a minute or two then connect it again.
