Originally Posted by drjoe
two noises i'm wondering about coming from a 2002 that i just bought used:
1. on cold starts, i'm sometimes hearing a brief high-pitched whirring noise about a second after the engine starts. lasts for about a second or two. sounds like the starter or a belt could make that noise, but the owner claimed the starter was replaced within the past year or so.
2. after turning off the car, the back exhaust/muffler system is loudly tinkling for several minutes before it cools. sounds as if little metal bugs are hopping around in there, but it's probably just the sound of the hot metal cooling. still, does that suggest a problem?
My '03 does both also and noise #1 only happen on a cold start and for 1 second, it sounds like when the syncho on a manual tranny is bad and you try to shift it into gear (gear grinding noise). It's probably something to do with starter and I've tiptronic. Should we be concern?
