Thread: Black HIDs
Old 04-20-2013, 02:23 PM   #34
clickman
Help! I can't figure out how to do the wiring with my stock daytime running lights.
According to the Bentley wiring diagram, there are 5 lights in the headlight module. High, low, fog, turn signal, side marker (park light).
I think what you non-DRL folks are wiring to the projector is low beam wires to the bulb and the high to the cutoff shield solenoid. Correct?
I was thinking of retaining the halogen high beams, which would mean splitting the high beam supply to the highs and the bi-xenon solonoid. Doable?
As the stock DRL uses the low beams, does anyone know if the DRL supplies reduced voltage to the lows and will that be an issue for the projector? Anyways, I'd rather use angel eyes for DRL instead of the low beams. Any way to do that?
Also, is it possible to keep all the wiring changes in the headlight module, including mounting of the ballasts on the outside of the end cap?
Anyone with a Canadian car done a xenon project retrofit?
clickman is online now   Reply With Quote
