springs & struts. the springs are shorter & the strut pistons are shorter (valving is identical to us).
you can use a U.S. strut on a RoW spring, but it will increase the effective spring rate slightly since these springs are progressive in rate.
you can also use a RoW spring on a U.S. strut, but they may rattle at full droop (like if the car is almost airborne).
