Old 04-19-2013, 01:15 PM   #1
insite
springs & struts. the springs are shorter & the strut pistons are shorter (valving is identical to us).
you can use a U.S. strut on a RoW spring, but it will increase the effective spring rate slightly since these springs are progressive in rate.
you can also use a RoW spring on a U.S. strut, but they may rattle at full droop (like if the car is almost airborne).
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
