I also had similar problem. 01 box.
it turned out to be broken "blade" in the turn signal light socket. the self-spring plate that the center button of the bulb pushes into.
my fix was to jam a thin metallic sheet to supplement the broken piece.
hope yours is not this bad. but you may want to look into the socket when you have the assembly out.
