Old 04-11-2013, 04:54 PM   #10
gavinyuill
Originally Posted by jeffm View Post
What are you guys seeing as a going rate just to have the odometer reprogrammed. I just did the silver/white face swap without issues. Unfortunately, the new gauge reads about about 10,000 miles over my actual.
Why this is not recorded on the ECU versus the cluster still stuns me.
If you just swapped the cluster to get upated faces, you can use the rear pcb from your old cluster on the new face pcb and your old mileage will be back.
If you no longer have the old cluster, PM me and I can help you.
gavinyuill is offline   Reply With Quote
