Old 04-11-2013, 03:50 PM   #11
gavinyuill
Originally Posted by juicepro View Post
Kevin, what tools do you need to take apart the cluster, just a torx bit?
Yes, remove 2 torx screws, then push the two clips on the back towards the outside of the cluster - this might seem a little scary at first as it feels as if they will break, but it disengages the electrical plugs that connect the two boards together, then unclip the large clip from the bottom of the cluster and it should fall easily into two halves.
gavinyuill is offline   Reply With Quote
