Old 04-06-2013, 06:53 PM   #2
Meir
1999 base
Meir's Avatar
Originally Posted by woodsman View Post
thanks for the response JFP. The pressure plate is a Sachs unit but it is supposed to have more clamping power than stock- something like 70 % good for around 400 HP. With regards to the release bearing, I see no method of attachment to the arm. There is nothing laying in the bellhousing and no hole for a spring or clip to fall through . Also they couldn't get the car to start with the new alu flywh and charged me 5 additional hrs labour for diagnosing . The old fly worked but the new would not but a week later and with another al flywh it started right up. I guess the clips got lost in the shuffle but would that be enough to actually prevent the clutchPEDAL from returning? Advice about the bolts taken.
(PS I won't tell you about the bent valves during the ims bearing install)
The realese bearing is suppose to snap on the realese lever, using a clip like strature that is part of the bearing.
