Old 04-01-2013, 03:54 PM   #3
KevinH1990
KevinH1990's Avatar
Consider checking the following:
1. Fuses
2. Ignition switch
Try a combination of searches such as: Fuse and "Gauge Cluster" or "Ignition Switch" and "Gauge Cluster" to see if someone else had a similar problem.
Another possibility is that one of the three connectors on the back has come loose. That seems unlikely unless you or a previous owner recently removed the cluster to replace a bulb and didn't reinstall it securely.
Good luck
