Disconnect the wire connector for the heated hard top rear window just behind the drivers seat headrest area.Look around a bit.It's difficult to see.
Remove the plastic pop off plate above the rear view mirror.Easy to do,just don't grab very hard and be sure to put it somewhere where it can't get lost.
There is a lever that was hidden by the plate that you just removed.Pull it down.
Behind EACH seat on the actual interior of the car body is a small lever that thankfully has a red knob on it to make it more visible.Rotate the lever up a bit and you will see it release the top a bit. After both are rotated up,have a helper get on the other side of the car and lift straight up and walk down the sides of the car to-wards the back and place the hard top on a blanket out of the way FAR from the car. DON'T run over it!The hard top only weighs 55 pounds but it is a 2 person job so that you don't scratch it or the car!
