Old 03-20-2013, 12:18 PM   #10
Meir
1999 base
Meir's Avatar
Originally Posted by Habby73 View Post
well, the tech manual i ordered (bentley) should be here tomorrow, and the thermostat soon after. I haven't ever worked on anything other than a front engine car so this should be an experience. any tips or past problems people have had when replacing the thermostat or water pump?
yes.
1. read this: Pelican Technical Article: Boxster Water Pump & Boxster Thermostat Replacement - 986 / 987
2. use OEM pump.
3. use OEM coolant.
4. inspect hoses, and replace if needed.
there is no problem i can think of.
in fact, up to date, that was the easiest project ive done on my car. (not including the small maintenance things)
one thing you should consider, is replacing the front engine mount at the same time.
if needed obviously.
