Old 03-11-2013, 12:15 PM   #11
Meir
1999 base
Meir's Avatar
Originally Posted by MFozz View Post
I've decided that since I'm in there I might as well replace the CV's as it's not that much more money.
One question, I can't seem to find which size bolts to order for my 2000S. Pellican doesn't seem to list a part for a 2000S and pcarspecialist.ca says 10mm. Elsewhere I've read it should be the 8mm. Can anyone firm which size?
the bolts you need are M10 mm. most likely 50 mm. you can confirm by measuring the ones you removed.
(10 mm refers to the size of the tread and not to the socket you use to remove it)
also take in mind the torque value (during installation) is 81 Nm/60 ft-lb.
use blue loctite. make sure treads are clean of grease, and don't forget to re-torque after 500 miles.
good luck.
