I replaced the same part last year. Your best bet is to remove the "T" plenum first because if you don't it will take you longer and just be harder to do in general, especially plugging the hard plastic hose back into the rubber hole in the sleeve. I hope that makes sense. It's not a hard thing to do but you need to pay attention to what you disconnect and where it was otherwise you may get a little confused when putting it all back together.
