Old 03-02-2013, 06:52 PM   #4
thom4782
thom4782's Avatar
I assume you mean the that you cannot get the headlamp assembly plug to connect securely to the wire socket that is held on the tower by the yellow clip. If I am correct, I can only tell you my experience and hopefully, it will do the trick for you.
First I slid / pushed the socket as far down as it would slide on the tower. Next, I inserted the headlamp assembly taking care to position it so the plug on the headlamp slid easily into the socket clipped to tower. It took a few tries to get things to align. Once, I was able to do this, the blinking off of the lights stopped.
