			Thom. Try this. If the evaporator is leaking, AC oil should be released along with the freon.
 Put the AC on high, and activat the defroster (direct the air to the windshield )
 After 5 minutes, use your finger and inspect he windshield for oily substance.
 If it is not oily, at least you will know the evaporator is fine.
 Did you charge the AC with a dye?
