Old 02-23-2013, 03:22 PM   #1
shadrach74
Still having horn issue...
I've posted about this once before. Here is the situation:
2002S
My horn does not work for the most part with the ignition switch in the "on" position, execpt for on rare occasions. It does however work with the key in the off position. I have replaced the ignition switch and it's not solved the problem.
Does anyone have any ideas?
Is it normal for the horn to work without the key in the ignition?
Is it normal for the horn to work with the key in the "off" position?
Would it possible for me to bypass the ignition switch all together?
Thanks in advance!
shadrach74 is online now   Reply With Quote
