Old 02-17-2013, 06:17 AM   #14
986FortyEight
Originally Posted by Jittsl View Post
I ended up with 3 relays. Fuel pump up front and 2 engine system relays at rear.
I also have a few more fuses than Brad. 1 each for wipers, lights (not really needed), brake lights, fuel pump, unswitched power and switched power - 6 total. I then added 4 that for accessories - cameras, Coolsuit, transponder and my face level blower fan. In my case a new fuse box is located on the end of the dashboard so that it is easily accessible and the original is gone along with the relay box.
Sounds closer to what I expect to see when I am done.
The new fuse box you mention, did you go the painlesswiring.com route?
Michael
http://imgur.com/aiZcIk8
986FortyEight is offline   Reply With Quote
