					Originally Posted by Skrapmot  What was the other 9? |
1. Change oil every 3-5K miles or once a year
2. When changing the oil/filter, check the oil filter for debris
3. Use a magnetic oil drain plug
4. Use an oil with high levels of ZDDP (anti-wear compound)
5. Install a spin on oil filter adapter
6. Drive the car sportingly - upshift above 3K rpm
7. Listen to the engine more and get to know its natural sounds
8. Install an IMS bearing monitoring device
9. Remove and check oil sump for debris every 20K miles
