Old 02-06-2013, 10:55 AM   #18
JFP in PA
Originally Posted by southernstar View Post
Mike, I have bills from the original owner and the engine numbers match the body (to the extent that they would denote a very early 2.7) so I feel safe in concluding that the engine was not replaced. I agree that, as engine numbers are not reliable, one is supposed to disassmble to determine whether it is a dual or single bearing. In the past this was not a problem as the ceramic bearing was available for both. Now they are only available for the earlier (double) and hence, after disassembly by my mechanic, I can only order a bearing if I have an earlier d. If not, I need to have the car re-assembled and shipped (or the engine removed and it and the transmission shipped), to and from Ontario, Canada. Or am I missing something?
Brad
Unfortunately, with a 2000-2001 car with the original engine, there is always some question which style bearing is in the car. That said, it is not that much of an issue to take the car apart and then overnight the correct unit. There is not much recourse to doing it this way, other than to buy both styles and try to return the unused unit.
