Old 02-04-2013, 12:27 PM   #5
thstone
Early warning indicators:
  • Coolent weeping from water pump (may or may not drip)
  • Small drops of coolent under engine
  • Smell of coolant from outside car or from passenger side engine compartment vent
  • Coolent repeatedly slightly low and needing "topping up"
  • Water pump bearing noise
  • Engine temp running slightly hotter than typical
When the water pump actually fails, you can expect one or more of the following;
  • Lots of coolent on ground
  • Clouds of smoke/steam from coolent burning off on engine
  • Heavy smell of coolent from outside car or from passenger side engine compartment vent
  • Engine temp going to max
  • Engine temp warning light turning on indicating max temp reached
  • Engine temp warning light flashing indicating need to shut down engine immediately
