Thread: winter project
Old 02-01-2013, 03:47 PM   #30
Meir
1999 base
Meir's Avatar
next step.
installing new flywheel and clutch kit.
used a home made tool to lock the flywheel and torque the bolts to spec.
if you are installing a new flywheel, look at the whit dot. this will help you locate the hole in the flywheel, that goes over the pin in the crankshaft.
after torquing the bolts in star pattern, and in two stages , i used the template from the pelican website to tighten the additional 90 degrees.
what i did, was marking the bolt on the top, and torquing it to the 90 degrees mark.
since i have a memory of a fish, that also helped me to see which bolt i already tighten.
clutch disk and pressure plat was installed. using the centering tool and the same method of star pattern and several stages of torquing .
