installing the new IMS cover using 3 6X25mm bolts from Ace.
using the bolts will help you drive the cover gradually to its exact location.
i turned each bolt one turn at a time until the cover was flush with the case.
removed the bolts, and installed the encapsulated ones, supplied with the LN kit.
some CurilT and the center nut.
