There is no need to remove the lead to get exelent access.
It's enoght to remove the metal clips on each side, and you will be able to set the lead at 90 degrees. The procedure is well described in the 101 book.
If you insist to remove it. You can remove all 4 clips, and pry out the joint.
Very easy and no need to mess with adjustment when installing it.
Edit: by the way, exelant tip on the starter low bolt removal.
