It's a 2004, the compression is good I don't currently have a leak tester but ordered one off Ebay. My motor is still in good condition so No rush to cut corners. Looking at replacing the oil pump shaft, plug, coil packs, Water pump, and installing a lower thermostat before removing any bolts from mine. No surprise the motor mount on it is split out.
