Old 01-07-2013, 07:33 PM   #4
steved0x
steved0x's Avatar
I just replaced the battery on both my keys, and on one of them the board popped out as the battery was coming out. There are a couple of little tabs in there, some are standoffs that hold the board in place and one (or maybe 2 of them) kind of snap over the edge of the board. There is also a little spring loaded arm that I believe holds the metal portion of the key in. Those little tabs may be off that clip the board in, and if so the board will not be fully seated and could block the two halves of the key case from coming together.
Good luck! My keys would still light up with the old battery but the range was very weak - it is much better with the new batteries now.
Steve
