That's interesting.
I never tryed to remove the passenger kick panel ( not even when removing the dashboard).
The driver side is held by 4 screws and clips, so I assume the passenger side is more or less the same.
Look closely and see if the crept cover hides any screws.
If not, it might be just fixed by clips, and all need to be done is pull it.
I will try to have a look at it tomorrow and post the solution ( if you are not gonna figure it out by then).
