Old 12-25-2012, 01:00 PM   #1
tonycarreon
tonycarreon's Avatar
Originally Posted by rondocap View Post
So the upgraded ims and clutch should run around $2k? Are they both always done together?
they're not required to be done together, but most of the work to get to the bearing is the same as replacing the clutch, so a lot of people do them together to save the double labor cost. same with the RMS. it's not a requirement, but the labor to get to it is mostly done when a clutch is done.
