Old 12-24-2012, 09:20 AM   #1
Meir
1999 base
Meir's Avatar
im not sure which version of the durametric tool you are using, but here is how it is suppose to look like:
the cam deviation values are presented on the top right, but what is more important, is that rock solid line at idle.
the values should not change even a bit (at idle) if all is right.
it is also recommended to change the oil every 3k mils, and inspect the oil filter for any metal debris.
