hi barkinfool.
i had the same experiences (including getting tips from TRK
you can read about it here:
Rear axels rebuild - Pelican Parts Technical BBS
and here:
Rear axels rebuild. O1 S
i also had an issue removing the CV joint from the shaft.
you will have to tap it to the direction of the transmission.
tap on the inner ring of the joint.
make sure you install it in the correct direction, and don't move it to much when it is of the shaft.
as you probably noticed by now, this is a messy job you don't want to do again anytime soon.
i decided to replace all 4 boots, replace the CV joints (even though mine was still fine) clean and grease the outer joint.
i had 76K on the car when i did it, and i intend to keep it for as long as i can, so it made sense to me.
