Old 12-17-2012, 07:41 PM   #1
Meir
1999 base
Meir's Avatar
Originally Posted by Bryan topping View Post
Thom,
On an '01 you need to have either the 4th stalk or the dashboard switch to indicate anything. I recently did this on my '01 with the dashboard switch.
Bottom line is the car needs to see a switch installed.
+1 on that.
I did the stalk last august (most useless mod I did on my car so far).
Even if you will be able to get the display you want, it will default to the temp display ( if I remember correctly ) once you disconnect the battery.
Instead of the stalk you can use a button and hide it somewhere.
If you need, I think I still have some wires that go into the cluster gray plug.
Just need to look for them.
