Thread: Reverse Switch
Old 12-11-2012, 09:41 AM   #14
Meir
1999 base
Meir's Avatar
Originally Posted by rene525d View Post
Thanks for your help guys. I removed the switch and cleaned it. Put it back in and it worked fine !!!! It was in fact 19mm. If I can't cancel the one I ordered I will keep it for later in case it gives problems again.
When I removed it there was a sudden release of gas. It lasted a few seconds ????? Car was cool did not drive it all of last week.
It was only a 10 minute job. Thanks again for your help guys you saved me 100 euro or so g
ooops.
i checked the size for you, but forgot to post it.
glad to hear you solved the issue.
about the pressure release. on top of the gear box there is a small braether valve.
make sure its clean.
i will take a pic tonight, and will try to remember to post it this time
